Boat is finally running right!
JasonA
Member Posts: 40 ✭✭
So I purchased a 2013 290 8.2 back in May and have been fighting issues for awhile now. I was using a mobile mechanic that finally ended up telling me cylinder 6 was dead. Before pulling the motor I decided to get a second opinion and drove the boat to a Mercrusier certified shop. They found 3 bad plug wires, a bad O2 sensor, bad water pressure sensor and a bad pulley. After replacing them all no more check engine light! They also took it upon themselves to swap out the B3 24p props for some 20p they had. Boat was running 4300rpm with the 24p and fought to get up on plain, with the 20p it jumps right up on plane and reaches 4900rpm with a full tank and two people on boat and stays on plane at a much lower rpm and actually has a higher top speed (the speedo on the dash was showing just past 45 at WOT).
Let's see who goes the furthest at 40mph! - oh wait, you can't do that!
So if you can get 27/28 with diesels, and a good mpg, sounds like the way to go!
Diesels you got and stop acting like a old deck hand....
ohhhh waittttt
your pic explains it all
rip my beloved 99.5 golf tdi=transmission died @375k=motor was still strong
stupid money to rebuild O1M
trip'n a way of life
