Question: Storing boat for winter-Bravo 3 specifically
04FV270riverrat
Member Posts: 268 ✭✭✭
I have my 270 on the trailer out on my in laws property for the winter. Whats the best way to protect the outdrive from water intrusion? I'm not sure if i can lower it low enough for any water that gets in to drain back out. Is wrapping it in a tarp my best option?
What I do is dump a bunch of -50 pink or -100 green RV antifreeze down in the exhaust ports in the drive. Better to have it there than to not have it there.
always lower the drive to its lowest possible position. When I trailered I would dig a small hole around the siege and lower it to full trim down.
not only is it good for your below sand rubber but no worry when it comes to water intrusion.
leave it to the beaver and let it breath
i had to replace few output shafts because of ice build up
just take the prop off and off u go
