Bravo III Prop Install
Best Answers
randy56 Member Posts: 4,085 ✭✭✭✭✭
the manual clearly states that B3 props do not need to be timed.Boat Name : -
RWBLACK6 Member Posts: 36 ✭✭
For installing B3 props, ALSWAG told me the following; after placing 1st prop on, turn blade up at 12 o"clock. Then place the next prop on with blades at 10 and 2 o:clock. He said , you do not want 2 prop blades lining up directly behind the gear box. As always , I follow his advice. -
raybo3 Administrator Posts: 5,559 admin
I called Merc and was told that there is NO timing or alignment.2002 342 Fiesta Vee PC Point Of Pines YC Revere MA. popyc.org raybo3@live.com -
rasbury Member Posts: 8,607 ✭✭✭✭✭
Well then! I will accept all your answers- there would be no harm then installing the way Al suggests as there appears to be no wrong way anyway.
Wish me luck,,,,,
Here is the e-mail response from Merc...........
Ray,
There is no special timing of the props. Service manuals for engines and drives are available from local dealers or by calling our Publications Department at 920-929-5040, option #4. Have your serial number ready when ordering.
Thanks,
James
MerCruiser Consumer Support
2017-00054090
Found old thread, hard to imagine the water getting so hot it damages props.
Why would Merc. tell raybo3 it did not mater?
https://rinkerboats.vanillaforums.com/discussion/6147/do-bravo3-counter-spin-props-need-to-be-aligned
Boat Name : -
Michael T Member Posts: 7,227 ✭✭✭✭✭
Why would a company say that a procedure "didn't matter"?
Does anyone remember the issue with servicing the jet engines on the DC 10s?
The proper way was to disconnect the engine from the huge bracket that connected it to the wing. That took about 200 man hours. Some genius found that you could remove a few huge bolts and drop the engine ( a few hours of work) - unfortunately - reinstalling it that way easily cracked the attachment bracket over time.
One DC 10 crashed at Chicago after its engine fell off on take-off. Plane crashed with the worst death toll in U.S. aviation history.
All DC10s grounded - none even allowed to fly into U.S. airspace.
Checks of all mounting brackets on every DC 10 done - dozens of more DC 10 brackets in imminent danger of failure.
Seems ALL of the airlines had shared the short-cut to save time/money!
The genius who thought-up the short cut caused many millions of dollars of damage and just under 300 deaths.
As my grandfather used to say you can do it fast or right - pick one.
ALL my boats - ALL my maintenance - of EVERYTHING I own......done right.
Who do you want working on your boat/car/sled......?
I'm with Al.
trip_n Member Posts: 747 ✭✭✭
Mine looked sort of like that, not as bad. Cleaned up with the works toilet bowl cleaner. not prop burn. algaeBoat Name : -
Well Handy not yours lol. Prop burn happens at high speed and high rpm. Not at speeds just above no wake - that's some funny stuff.....I will time the props and will look for the thread or check the manual.....thanks Al as always! soot on the props...yuk yuk yuk.... -
Black_Diamond Member Posts: 5,439 ✭✭✭✭✭
Prop burn is really cavitation. Bubbles forming at the blade surface that erode the metal. Common in pumps with metal impellers, can be very damaging.
PC BYC, Holland, MI -
Since a few day's ago hearing about prop burn for the first time. I've some research. Here's the good description found.https://youtu.be/5bj5kjh3l9o
Boat Name : -
I clocked my 4x4 props. Always did my old 3x3's too. Takes zero effort and maybe 30 seconds of your time.
Here is an easy to read explaination:
https://www.thoughtco.com/cavitation-causes-and-remedies-2293276
In short - hydrodynamic cavitation is caused by the explosion of tiny bubbles created by pressure differentials across the surface/edges of a propeller. The (new) and largest container ship in the world has two propellers (4 blade I think) that cost a million dollars each to pour, cut robotically and X-Ray. Many propeller designs were tank tested to find the best design to reduce propeller "eating" cavitation. You also have anti-cavitation plates on your marine engines that help a bit too. Cavitation also affects skegs etc.
