Rinker 28 Express Cruiser - Water Leak
Hi, excuse my lack of nautical terminology but have just purchased a 2009 Rinker 28ft Express Cruiser in the UK. The seems to be a sizeable water leak at the rear sleeping area that 'pools' at the footwell at the bottom of the stairs leading from the cockpit.
I have not got a clue where and how to start looking, hence posing the question to see if anyone out there has any experience or heard about this. I can forward a picture.
Thank you in anticipation.
Best Answer
TikiHut2 Member Posts: 1,431 ✭✭✭✭✭
Welcome to the forum!
Don't rule out internal issues. It could be a malfunctioning shower sump pump, an overflowing a/c drain pan or a poorly connected/cracked sink/bilge/etc drain line.
Outside caulking issues are often found with a friend squirting a hose on suspect areas while you observe with a flashlight from inside. Another option is baby powder sprinkled inside around suspicious areas and later-checked for indications of drainage.
It's a battle to keep water out of the boat and there are quite a few battle fronts to defend. A particularly pesky leak on a former boat came from a tiny gelcoat imperfection in the broad area of a foredeck that dripped inside the headliner and ran across to a totally different area. Usually it'll be something far less challenging.
Others will chime in I'm sure. Good luck and let us know what you find. Mike
2004 FV270, 300hp 5.7 350mag MPI Merc 305hrs, 2:20 Bravo3 OD w.22p props, 12v Lenco tabs, Kohler 5kw genset, A/C, etc.etc...Regular weekender, Trailer stored indoors, M/V TikiHut, Sarasota, Fl
I think RBOC member Tony mentioned an arch leak in his 342. Do a search in the archives and it may come up.
Do you keep a travel cover over the cockpit? Have you eliminated anything already mentioned by RY or myself? Our boats former owner hadn't properly latched the aft cabin port and it allowed water to enter the aft bunk area. Rule out the easy stuff by checking that all the ports are secured as RY said, check the shower sump pump and galley sink drains with a good flow of water too.
Hey, now you know port from starboard.....you're on your way. Haul away.
oboy,here we go...
I had issues with my 270 leaking and pooling in the exact same location
I couldn't find the source of the leak.sooooooooooooooo...
1)the windshield on my 270 wasn't installed properly...the holes drilled in the fiberglass were not countersunk nor were they sealed with any kind of silicone or 5200.
I had to redo this at my expense
2)the rub rail hull to deck connection was not sealed at the factory.
there were many holes/gaps so I had to pull the rub rail and seal all the holes.
then put the rub rail back on and seal that as well.
3)I pulled out every speaker,carpet,screw and cushion and EVERY snap and sealed them all.
rinker said I didn't have a leak....um yeah,ok
2007 rinker 270
"Julie Ann"
from your description also don't rule out the frig leaking..
2007 rinker 270
"Julie Ann"
The hull to deck connection at the rub rail can certainly become compromised with a whack from an unexpected dockage miscalculation so I'd check the whole side under the rail for damage or proper sealant.
Good call on the frig condensation. I use my teeny frig as a dish/silverware/glasses storage locker anyway. Beer n food in Fla deserves to be in a cooler on Ice. How 'bout our endless rain down here this year, 3" today alone. Testing my sealant every day. So far so good. Mike
I'd latch those ports down tight and hose them to see if it's the source before I tore them out to re-bed.
Good luck with the leak. Keep us up to date on what you try and what eventually works. Pictures are a universally understood format. Fair winds, Mike
I posted a detailed work instruction on here somewhere about the windows. They are a two piece assembly: the stainless steel trim ring and then the window itself. The window frame comes out from the inside (there is a screw behind the window hinge! hard to get at unless you take the hinge apart - which is not hard). You need to cut the caulk at the trimring and the plastic part of the window and it will pull out (from the inside) just be careful and patient. The trim ring will be obvious how it is attached, be VERY careful taking it out as it will bend. A little heat on the metal where it meets the hull will break the caulk seal once you take the screws out. I used a full tube of caulk per window to reseal.
If you can verify it is the problem and want to fix it ourself, drop me a note and I can get you all the details. I tried searching on the forum for my posting but no luck.
Leak update: Hi again, i was at the boat last week and attempted to gain access to the area directly under the window. After removing what seemed like hundred of screws i was no where nearer being able to see anything. in the end i managed to prise away the cupboard/shelving unit around the window, however, i couldn't see anything.
Over a beer (actually 3) i decided to consider using a process of elimination so i taped plastic visqueen over the window and though would revisit this coming weekend to rule in/out the window.
Have also planned ahead in case this is not the cause, so will place gaffer tape over the entire rub rail and have borrowed a small inspection camera so i can have a look around the radar arch.
Fingers crossed.......
before you buy that beautiful instrument, listen to my story:
Also we had a very wet floor under the stairs in our 280EC 2007 cruiser.
Not only the floor was wet, also the area with the toilet valve and the shower pump was filled with water. After confirmation of being clean water (not outside water), we found a broken waterhose connection in the cold water line in the toilet area under the sink. We removed the cabinet under the sink and were surprised about the speed of dripping water concentrating at the bottem of our carpet.
Try blotting it up with papertowel or a white towel. Unless the water in your marina is exceptionally clear, you can see if the water looks dirty. If you dry it up and leave your water pump or hose OFF does it stay dry? Using the city water connection and leaving it on when not at the boat is not a good habit by the way. It would have to be a hefty leak to pool like you say and be from a leaking window.
As noted by others, I would look at water lines, shower sump, AC condensate drain, check your AC and toilet in-line water screens too. I had a leak at my AC in-line screen as the threaded connector for the water line was not teflon taped and was not tight either.
**EUREKA** found problem (well actually problems). Hats off to "Tikihut"; found problem to be water entering radar arch in two places: One was the navigation light and the other was where the arch and the body meet. The water was then entering the cabin via inadequate sealing and also via one of the three bolts fixing the arch to the main body of the boat.
For some reason the middle bolt had no mastic or sealant (unlike the other two). I have now gone out and purchased two tubes of marine grade sealant (had to cover holes/gaps with gaffer tape as a temporary job).
Have to say bit disappointed with the cause (manufacturer), especially as the boat is only four years old and also the lack of response from Rinker.
Lastly, suppose also a bit disappointed in the surveyor who carried out a survey just before i bought the boat. In hindsight there was a bit of a 'telltale' as some of the water that must have been entering where the navigation light is housed had caused some lifting of the paint directly underneath (there is a small inspection hatch).
Rather than attempt a repair to the paint i am thinking of having a glass diffuser cover made and will install some led lighting as this will be cheaper and aesthetically better.
yeehaa....... can get back to dry and happy boating
Yeah, These aren't custom built boats and they're assembled by guys working on tough production schedules in a pretty brutal environment so we usually have to do a little detail work if we end up with a boat part assembled by the guy who squeezed past H.R. or is just an underachiever. Caulking is ok, poor drive alignment or misplaced cotter pins are another story. Just sayin'.
Good luck with the rest of your boating season and keep us informed about how it's going. Pictures are always good too. Mike
NTB,
I finally opened your thread. Leaks are strange and hard to find things as you know. Congrats for finding yours. I think the last of my leaks was finally found and fixed.
It was a defective/deteriorated seal on the opening port in the head. That was found by the guy who does most of the work on my boat. He was working, installing a new fridge during a heavy rain. He heard water running in at an audible rate and traced to the port hole. I think that was my last leak.
On remembering port/starboard etc All the long words are on the starboard side: Right-Starboard- Green and the short words are on the left side: Left-Port-Red. An easy way to keep track.
Tony
Salt Shaker 342
