Toilet Help (LOL)
Hey guys - Need a quick confirmation regarding the heads. My boat is under shrink wrap right now so I can't climb in to confirm but I am replacing my toilet this spring (whole assembly with hand pump) but I just want to make sure I have the right model. I am 99% sure that there were only two different models that Jabsco makes one is pre a current year and the other is after a current year. My 280 is a 2007. If anyone can confirm this it would be appreciated!
Boat Name: Knot A Worry
size
of the bowl which for you it’s standard size and either manual or auto flush
i replaced mine last spring and it was 30 bucks cheaper going with west.
yes it can be converted pretty easy. All you need is a power source going to the auto flush. So basically running few wires.
if you have room to with large bowl
but from my experience standard was put in for a reason lol
no room otherwise and mounting holes would be off since larger bowl would probably have to be shifted some.
http://www.xylemflowcontrol.com/marine-and-rv/electric-toilets/58500-series-lite-flush-toilet.htm
you can always just put the water pump right at the current manual pump water pickip and be done with it.
