First time changing the Impeller
joey91279joey91279 Member Posts: 19 ✭✭
Hi Rinker friends,
I will attempt to change my first impeller this spring on my 2005 Captiva 192.  I was wondering if the job is difficult and I will be able to do it on my own or do I need to take it in and have a professional do it.  I do watch a lot of youtube videos on how to do things on the boat.
I do appreciate any feedback or help!
Thanks,
J
    You can and should learn to do it yourself!  That way, if you ever lose an impeller while you are out on the water, you can fix it without having to wait for help.
    The difficulty depends a lot on your boat and how hard it is to physically reach the pump.  Maybe some other 192 owners will chime in with details.
    Most likely there is a you tube out there that will take you through it. I have 2006 350’s and I can tell you that if you have a 350 there is an awesome step by step thread out there that I used to do this myself. Took a few hours to do two engines. You need to buy a set of short stub wrenches and you need the 10mm stub wrench. Will make it easier, harbor freight has a set for less than $10
    The key is to find the bolts that attach the pump to the engine, and remove those bolts first.  Then you can remove the pump and work on it in a comfortable position.
    If you need to change the impeller while the boat is in the water, here's a trick.  When you remove the hose that supplies water to the pump, sea water will start flowing out into the bilge.  Don't panic!  Just stuff a rag into the hose to stop the water flow.  Make sure it's tight enough to stay in place until you finish the repair.  You might end up with a gallon or two of water in the boat, so turn on the bilge pump.
    Oh, and maybe take a photo of the serpentine belt before you remove it.
  • Dream_InnDream_Inn Member, Moderator Posts: 7,851 mod
    First, what drive do you have? If it's an alpha, the the impeller is in the drive itself. If it's bravo, then I agree with comments above.
    I was wondering the same thing @Dream_Inn . A 192 more than likely has an Alpha drive. I have never seen a 192 with a B3, but I am sure it has been done.
    All above comments assume Mercruiser. Volvo Penta has impeller on crank pulley and is very easy to replace. I don't believe there is another impeller in the Volvo outdrive, either SX or DP, but not 100% certain.
    Comment withdrawn  :D:D
    Alpha one drive pump can be done without removing the entire drive. You can separate upper from lower and bang
    Yes, I've done it this way once or twice.
    Yep, same here.  Just need to be really careful of the drive seal when putting them back together.
    Well you have upper seal and oil seal really
    everything else is pump housing related.
    just get a merc or Sierra kit and you will be just fine.
  • nhsdnhsd Member Posts: 182 ✭✭✭
    As noted, if it is an Alpha drive the impeller is in the lower unit of the outdrive. It is a pretty simple task. I have done mine a couple of times and believe me, if I can do it, you can do it :-)  The hardest part is putting the lower unit back on and that is pretty basic if you have a helper. I did it by myself and it was a bit fiddly to get the alignment done while hefting that thing up But again, very doable for even a pretty rank amateur. Check out a couple U-Tube videos. There are several good ones out there.
    Dave
    Moon Township, PA - boating in the Ohio River
    N yes read, ask or YouTube
  • joey91279joey91279 Member Posts: 19 ✭✭
    Thank you all for replying!  The outdrive is a Mercruiser Alpha. I have watched a few YouTube videos and it does look easy,
    I had a bayliner with an Alpha 1, never replaced the impeller and never overheated...something like 6 years!!
    I you do split the outdrive without taking it off make sure you drain all of the lube including the reservoir.
