oil extractor pump
GMSLITHOGMSLITHO Member Posts: 1,600 ✭✭✭✭
Can anyone recommend one
    And a washing machine hose
  • aero3113aero3113 Member Posts: 9,419 ✭✭✭✭✭
    Washing Machine hose works great! From what I remember, I think I had to drill the hole a little bigger on the fitting on the hose to fit the dipstick tube snug.
    I use a hand pump from west marine, big canister, pump a few times and the oil flows in to a canister. Works great!
  • Cableguy GregCableguy Greg Member Posts: 5,049 ✭✭✭✭✭
    I have the one that goes on the end of my drill. It also works great.
    X2 on the drill with clear hose works great just make sure its warm.
  • rasburyrasbury Member Posts: 8,605 ✭✭✭✭✭
    Ditto here...i have the drain tube...i put the hose in that and suck it right out!
    I pop the drain plug on the oil pan and drain into the bilge.
    once drained I flick the bilge pump and enjoy a cold drink.
    like 8 for every quart I dumped lol
    IMO
    If I were going to keep a boat for any length of time I would remove the drain plug from the oil pan and install a brass fitting. I listed all the part numbers for the different oil pans a couple of years ago. I would attach a purpose built oil/heat resistant hose to it and then an electric oil pump. Using this removes the oil in a couple of minutes.
    The first one I had installed on a boat was in 1994. The technician said I was wasting my time. He said the system used by the marina (a white pail with a pump on top - everyone has seen these, right?) would have gotten everything but a few ounces.
    I told him I doubted that. He pulled the drain plug and started yelling for rags. He burned his hand as hot oi ran all over it (we had - obviously - heated the oil before removal to draw all contaminants into the oil) .....and about a pint of oil drained out.
    Anyone who thinks they are getting all of the oil out via a dip stick removal system is dreaming.
    For a few bucks and 30 minutes work install a proper removal system.
    Good post Michael, I agreed this is the proper way.
  • Dream_InnDream_Inn Member, Moderator Posts: 7,763 mod
    Hey, I am Dream 'Inn! :)  I've always had the drain hose on the bottom of the oil pan and have one of those buckets with the 12V pump.  Connect to hose, turn on switch, have a drink!  2-3 minutes later, done! :)
    @Dream_Inn....awesome. I installed small 12V electric pumps in the engine bay, wired and fused them to a battery with a hose long enough to reach a couple of jugs on the dock or boat deck. Flip the switch and done. To get the last few drops out I would pinch the end of the hose closed to build vacuum in the pump and release it into a jug - bam - the last few ounces gone!
    I like the idea...but id have no idea how I would reach the drain plug.
    edited February 2018
    @skennelly, agreed it's not easy. Several times we have used an off set wrench to get a bit of room but it does require some acrobatics.....and the installation of the 90 degree elbow for the hose does require some blind feeling around and care not to cross thread the oil pan threads! Of course when anyone lifts an engine (IMO) putting that rig on should be part of the plan.
