342 swim platform backing plates
Black_Diamond
Member Posts: 5,439 ✭✭✭✭✭
Replaced the stacks of washers used on the bolts to fasten the swim platform on. Used 2.5” x 5” AL plates. Plenty of support now!Past owner of a 2003 342FV
Will help spread the load better with my dinghy. Esp with the Lk Mich waves! I was seeing some stress from the washers, likely from over tightening when it was built. One of those things that just kept bothering me. lol there were (2) bolts I could not use the plates on: one was in a corner and the other was drilled thru at a bad angle thru a radius on the transom wall. So 16/18 have backing plates now.
I got the plates cut to size from:
https://www.cut2sizemetals.com/aluminum/plate/apl/
6061 Al, 1/4” thick. I primed and painted them too. Just looks nicer.
If I ever need to tend to the platform side, I’ll pull the whole platform to seal.
Any ides on where to get stainless plates like BD found?
More $ for SS, harder to drill too. Really no corrosion issue to be concerned with using AL. I liked the 6061 AL as it can flex a bit to deal with a non-smooth/flat surface, SS would be quite rigid at .25” thick.
You’ll 2-3x the cost using SS.
Doing the plates I used in SS was a near $500 bill. AL was like $150 or so. Or close.
I can save about $40 by ordering 9 plates at 2.5x10 and cutting them in half.
I have the integrated swim platform (2007 280 EC), and added a grill mount to the starboard side by the cleat. I had my wife hold the screws from the outside while I wiggled on my belly, over the blackwater holding tank, to reach the backside. I watched a Black Widow crawling on her web near the rear of the 496 as I added washers, nylock nuts, then tried to spray them with lube (to prevent the stainless hardware from galling). The wife had to run off a few times to check on the kids while I laid there, waiting, in a very uncomfortable position, watching this Black Widow and wondering how fast she could really move. By the time we got all 6 tightened I was almost stuck - my core and lower back were so cramped up I couldn't wiggle back around the hatch support. That spider would be fat, dumb, and happy after eating me.
I am glad I didn't install the starboard. Thanks Liberty.
My thoughts were that it has to be better than no backing plates. But if I am going to add backing plates, I might as well do it right and go with AL or SS.
I used 1/4” thick aluminum plate, it is far stronger than you need. I primed and painted mine, an OCD issue on my end. You don’t even need to paint.
