01 rinker 212 stainless prop help
Just purchased a 2001 rinker 212 special edition with a 5.7 and am looking to upgrade the aluminum prop to a stainless. Any advice on size?
what gear ratio is your leg?
I finally rested on a 22p stainless steel three blade 14.25" diameter 'turbo1' by precision... it is a vented prop, which spools up off idle and out of the hole like a 21p... I'm really happy with it, and I got a stupid good deal on it.. If I had my absolute perfect selection, though, it would be the same prop a pitch shorter, still vented, (21p instead of 22p)...
you could likely turn the vented 22p perfectly, or a similar geometry 21p un-vneted..
that is my recommendation for you, and assuming you're running a 1.6ish gear (as opposed to my 1.8ish gear but powered less) : 22p Turbo-1 by precision in stainless steel, vented, 14.25" diameter three blade.
Dave
:-D
B-)
:ar!
