01 rinker 212 stainless prop help
Just purchased a 2001 rinker 212 special edition with a 5.7 and am looking to upgrade the aluminum prop to a stainless.  Any advice on size?
    oh boy... I feel for you- I just went through this... luckily for you, I run an '05 captiva 212, and likely is a very similar if not duplicate hull design.. I'm considerably powered less, though, with a 4.3l/190hp...
    what gear ratio is your leg?
    I finally rested on a 22p stainless steel three blade 14.25" diameter 'turbo1' by precision... it is a vented prop, which spools up off idle and out of the hole like a 21p... I'm really happy with it, and I got a stupid good deal on it.. If I had my absolute perfect selection, though, it would be the same prop a pitch shorter, still vented, (21p instead of 22p)...
    you could likely turn the vented 22p perfectly, or a similar geometry 21p un-vneted..
    that is my recommendation for you, and assuming you're running a 1.6ish gear (as opposed to my 1.8ish gear but powered less) : 22p Turbo-1 by precision in stainless steel, vented, 14.25" diameter three blade.
  • nhsdnhsd Member Posts: 182 ✭✭✭
    On my 2002 212 with a 5.0 carbed 220 hp engine I am currently running what I understand to have been the stock Quicksilver Vengence 13.75 x 21 pitch 3 blade stainless. I also have a 14.25 x 21 pitch Turbo 1, but find it just a touch too much for my engine/outdrive combo when I get a little weight in the boat. It might be a great prop for you with more power, but obviously a lot depends on the outdrive type and gear ratio. Mine is an Alpha I with (I believe) a 1.61:1 gearing. I think Drewactual has an Alpha I with the 1.81:1 or some such ratio. With a 5.7 I kind of assume that you either have a Bravo drive or an Alpha 1 with the 1.47:1 gear ratio. If a Bravo, please disregard my post. If the Alpha 1, the Turbo1 or the Vengence at 21 pitch would probably be a pretty good fit and you can find used for sale pretty decently priced.
    Dave
    Moon Township, PA - boating in the Ohio River
    tell ya what, Dave, you swap the 21p for my 22p turbo 1, and then sell him my (now your) 22p turbo1, and we'll all be set!!
    :-D
    B-)
     :ar!
  • burtoncmuburtoncmu Member Posts: 2
    gearing is an alpha 1.47
