Salt water and longevity
I found the below listing interesting even though it is almost 1100 miles away from me. I have not contacted the seller as of yet. I was looking for input from others about what kind of toll lifetime (of the boat) salt water use takes on a boat and engine without fwc. I know exhaust elbows and some other wear and tear items need replaced over time regardless of water type but how about block and drive longevity? Opinions welcome!
http://www.boattrader.com/listing/2004-rinker-fiesta-vee-270-express-103199775
-Paul (boatless and bored)
She looks clean and with no bottom paint, that means it wasn't left in the water for long periods of time. That is a good thing with the salt water. If it was flushed after use, then you may not have any issues with being ran in salt water. Normal wear and tear and issues with age may be all you'll have problems with. I think you should have one our Florida guys take a look at it for you!
Only thing I'm curious about is that the trailer has only been in the water less than 10 times. To me, that can only mean they keep it in a high/dry and gets put in out with forklift (which is a good thing), so it probably also gets a quick pressure wash each time out, but I'm betting not an engine flush (unless lift kept).
Although he is talking about an outboard I think an inboard engine would have the same issues. For that kind of money I think I would have it surveyed. Good luck finding one, there are a lot of them out there for sale.
-Paul
-Paul
