Fiesta Vee gel coat
ronfl818ronfl818 Member Posts: 2 ✭
I have a 2005 fiesta vee 250. Need some gel coat for repairs . Just a small amount. The boat is a bone white and tan. Any idea where I can get a match.
    edited February 2018
    I have filled some holes with the $30 kit from West marine just a drip or two to match the color has worked well for me.
  • Dream_InnDream_Inn Member, Moderator Posts: 7,964 mod
    Spectrum color is usually pretty good.
  • aero3113aero3113 Member Posts: 10,031 ✭✭✭✭✭
    I used Spectrum patch paste kit to fill holes on my dash, came out great.
    http://forum.spectrumcolor.com/Items.aspx?code=K&key=cat
    Aero, how does the patch kit work? I’ve got a 3 ft scratch from the PO, would one of these kits work well for that?
    It should work fine. Just add the hardener to the paste and mix. Fill the scratch(the less you use the easier it will be to sand even). Once the scratch is filled you tape a piece of plastic over it. I think I used the plastic from a zip loc bag.The plastic bag helps it cure and gives it a smooth surface (the resin doesn’t cure to the plastic). Once it sets peel the plastic off then all you have to do is sand it using various grits,compound, polish then wax. It was a simple process. The kit comes with instructions.
    You can use a plastic pudy knife to spread it over the scratch evenly.
  • GMSLITHOGMSLITHO Member Posts: 1,626 ✭✭✭✭
    can you tell me what color you used it looks great
    Thank you, I bought 2 different colors Rinker Bone and Rinker Sand (I had some spots on my hull that I fixed also). I forget what color was for the dash, maybe Rinker Sand?
  • ronfl818ronfl818 Member Posts: 2 ✭
    How do I know what color will match my boat? Is there only 2 colors for the year?
    My 01 only has 2 different colors, yours might be the same.
    If your boat has tan sides, the matching color is Pewter. The while looks like Sand White. I am not sure what the dash would be.
