Kohler 5kw Generator Maintenance
I have a 2004 270 FV and can't find my manual for the generator. Does anyone know what model Kohler 5kw generator is in the 2004 270 FV? Maybe the sparkplug model #, fuel filter and oil filter? I am doing most of maintenance myself now and I think my old mechanic kept my manual.
2004 270 Fiesta Vee, 496 Mag
The manuals are in the generator section.
Get rid of the fuel filter that is at the inlet to the fuel pump, just use an in-line one.
Spark plugs: NGK BPR-4ES
Oil filter: WIX 51394XP
For those of you who have had issues starting a 5E generator after some time of no use, there is an easy fix that was brought to my attention by a very nice mechanic who did not charge me to come out and fix it but walked me through it over the phone. There is a small plunger type device at the bottom of the carb bowl with a wire connected to it. You will have to unscrew it from the carb and clean the needle plunger with carb cleaner and once complete, your generator should start right up.
Ras, actually it's less than a dollar! Not sure why I hadn't changed it. I think it's just a matter of remembering. Honestly, I've not even looked at where it is, but I know others say it is right behind the impeller.
