Removed 5e carb, fuel leak
Liberty44140
Member Posts: 4,414 ✭✭✭✭✭
I removed my kohler 5e carb yesterday with plans to clean & rebuild it. I already bought the rebuild kit from partsfortechs. As you can see I replaced the ads two years ago.
anyway looks like it has been leaking fuel. Part of the reason I wanted to rebuild was that I get a fuel smell in the cabin after shutting the genny down (which yes I know is very very bad hence rebuilding now). Issue is this, I can’t tell
if the ads, spring screw or bowl screw were leaking. Before I rebuild I wanted to put this out there for your thoughts and comments. Is this rebuildable or should I be buying a new carb? I plan to call partsfortechs to see if they have any rebuild diagrams.
Post edited by Liberty44140 on
Partsfortechs is great.
surprisingly the idle screw at the bottom of the bowl was screwed all the way in, don’t know if that is normal or not?
Anyway carb all re built and re installed. Was very clean inside. At this point if I had to do it over I’d pribably just replace the carb for $240 rather than buy the $45 kit. I bought a new ads for $100 two summers ago so I didn’t want to buy an entirely new carb. Main reason I don’t think I’d rebuild again is that that ridiculous white paint flakes off when you start working on it and then add carb cleaner and it really starts to flake. Was a mess and really hard to keep it out of the carb. Had to be really careful and blow it out. Looks great now so hopefully it starts faster and no fuel leak this spring, if I have any issues I’ll just replace the entire carb and be done with it.
