Anyone with a swim platform template for a 2003-04 312 or 320 2005 -2008 on digital format?
ApriceAprice Member Posts: 125 ✭✭
Hello all. Was wondering if anyone that has put the Eva foam on their platform  has the digital template still I can use to order one for my platform? Thanks in advance.
Anthony Price
The Price is Right
MacRay Harbor, Harrison Twp., MI
    Did you try SeaDek? They might have one and I have heard that they will send it to you if you are considering buying one from them.
    Aprice, was thinking of doing this as the swim platform is slippery as ice when wet. At the T.O. boat show the local Seadeck installer said around $800.00 to install. I thought that was a little pricy . Was thinking of doing something myself but have several projects ahead of this. I noticed the dreaded list to starboard is not as bad as mine. You must have holding tank pumped and fresh water filled. Lol
  • ApriceAprice Member Posts: 125 ✭✭
    I did try Seadek @Cableguy Greg. No luck.
    @goalie59 yeah that list is annoying. Was looking to move the batteries maybe this spring. We will see. Can't have too full of fridge in the cabin and cockpit either. I have considered adding some weight to the port side about mid berth to help too but I can only tell when I am bit in the boat. And for most of us that is more of a problem itself.
    Anthony Price
    The Price is Right
    I don't think the batteries will do it as there is already the house ones on the port side.  I have had two people sitting on the port bench and the list is still there.  I love the boat but the layout is poorly designed. Something that you have to live with
    I believe it depends what you have for batteries and how many. I balanced a 2011 Rinker 226 XL by moving the starter battery and a series 31 AGM to the port side of the engine room. Made about 3" difference at the water line. On the 2014 EC 360 putting 4 Series 31 AGMs on the port side completely leveled the boat. So, I guess it all depends. At 70 pounds a battery it doesn't take too many to effect change?
    I am planning on moving my 2nd house battery to the port side to try and level my boat out. Like you stated @Michael T , it doesn't take much to make a difference.
