Where can I get these connectors?
Hi everyone. Forgive me if this was covered in another thread, but I couldn't find it. I have a 2000 FV 270 and need to replace a few of the A/C connectors. They look similar to the one below. They come in various colors and configurations depending on the circuit to which they are connected. I've looked high and low and can't find them anywhere. Anybody have a clue? Thanks.
You will probably be able to change the internal connectors and keep the shell.
See similar attached. Not sure these are exactly what you want, just something to point you in the right direction.
https://uk.rs-online.com/web/p/heavy-duty-power-connectors/0534985/
https://powerwerx.com/powerpole-chassis-mount-plug-latch-4
Just across the bay from where I berth my 270 are the "Dr Who" studios, so these things are quite a common sight around here. I've even seen them on a boat.
https://en.m.wikipedia.org/wiki/Dalek
a) Occasionally - often at startup after winter - there's no hot water when on shore power. Digging around I found this at the hot water system and pulled the 2 halves apart, looked and clicked back in and after that all seems okay. I thought maybe after launch and bumping around something jostles loose and I remake the connection. But.....
b) Twice now an instantaneous overload condition - had microwave going and forgot and hit the kettle for the admiral's tea - I hear a click and the shore power light drops and no power - AC line is still good. The very first time this happened it was after a cruise and after pulling power etc and back on with nothing, I thought maybe a loose connection, spark and disconnect so I pulled panel. Found the lead in with these connectors, split open, looks good, put back and then all is well. Hmmm.
c) Yesterday at dock, not out since back Sunday same thing - hear click, no AC led, thinking maybe a thermal overload so I left shore power disconnected at incoming socket on hull for at least 60 mins and with breaker off. Come back, plug in, flip on breaker - nyet. Take out 4 screw to panel, pull it, unsnap same connector and plug in - up it comes. It's like these have a mechanical function.
I haven't had a chance to look at these devices but anyone care to add thought - besides I am way off on my idea
Oddly all seems tight and no rhyme nor reason for what I am observing.
And yes, I worked out the pin that @dalek mentioned, made sense with a closer look.
I'll get me a 3 pin locking plug and socket pair x 3 and make them all the same. Seems these can work loose and start to spark over time.
