what the heck size socket for the Y exhaust
rasbury
Member Posts: 8,823 ✭✭✭✭✭
Trying to get my Y pipes off...Have tried metric and SAE and neither fit....3/8 tad to big and 10MM tad to small...what the heck size is this?
Best Answers
rasbury
I have them soaking....and I think your right. The replacement part is 3/8" -
212rowboat
Member Posts: 2,593 ✭✭✭✭✭
i had similar issue, @rasbury.... ended up using an allen key- a really thin one (don't know which) and slipped it between the rounded bolt head and the inside of the wrench jaw, which gave me enough bite to extract it.
just an FYI, though and for anyone else reading this thread:
this is one of the things i look at when considering buying a boat. not only these bolt heads, but those on the intake manifold, water pump/timing cover ect.... the transom plate grounding connections are obvious if they've been removed as an example... anything with a bolt head will tell you if it has been removed after factory install. if the paint is broken or if they're even slightly rounded, it's clear evidence 'someone has been in there', which may or may not mean good things. the fact your Y has stripped or rounded boltheads indicates either the previous owner hired a gorilla to torque everything down, or he didn't take care to do things right.... which means he may as well had hired a gorilla to do it all. it isn't a show stopper, but what the previous owner has to say about it when you question him about this 'indicator' may be a show stopper. -
rasbury
yea, not sure...the boat only showing 100 hours on it when I bought it, I figured worst case he was one oil change behind and I can't imagine why it would have been torn into. The bolts to the out drive looked good, the bolts for the y did not look coraded or anything....so eventually I just cut the y pipe with a reciprocating saw so I could pull what was left through the key hole. I will post a series of pictures of my misadventures on the bellows thread I have going. I'm officially all torn apart now, putting my parts list together and hopefully can turn the top of my rachet to the tighten instead of loosen, that's always a good thing!
