Spring list
zaverin1
Member Posts: 1,672 ✭✭✭
Hull wax is scheduled so is the fiber guy to do few minor touch ups.
next is spark plugs
drive service
install new block drains ( original and stripped out )
button up shower box exhaust hose from last spring install lol
put silicone around the rub rail and side port windows
new deck Carpet backing sprayed on
installed new fuel caps since ones I had were original and seals were gone
next is spark plugs
drive service
and bottom
https://www.wholesalemarine.com/3m-marine-grade-silicone-sealant-35164.html?gclid=CjwKCAjw7tfVBRB0EiwAiSYGM1e7RblwZ2B4YkcdCENl4nStIwf1xyysTwmYoW8y_xgFtnJpnPOGaxoCB3AQAvD_BwE
I've been watching this thread because I'm facing the same job of re-sealing my port lights and rub rail. The part of the above article that really caught my eye was regarding silicone not sticking well to previously applied silicone should you ever need to do the job again.
if you prep the surface area with your choice of prep you will have zero issues.
my port was fixed at one time or I should say sealed with 3m since it’s white. Started leaking in heavy seas.
