Access to stereo / microwave 2002 fiesta vee 270
 drewc64
                    Member Posts: 10 ✭
drewc64
                    Member Posts: 10 ✭
                    Updating the head unit that was in it when I bought it.  It has to be original since it has a tape player.  There is no way to get into the rats nest of wires between the stereo and the amplifier.  Does anyone know how to get back there?  There are screws that run down the side, but after removing them the whole console is still solid as a rock!
second question. Where would YOU mount a subwoofer in the cockpit???
i removed the screws from the trim that butts to the hull. No luck.
i have a different microwave. Could not get it out from front. If I could there would be almost enough room to get in there.
If no one knows how to get behind all that stuff, who can weigh in on where to put that sub. There is a storage bin to the right of the helm. Thought of removing that and making the open a bit bigger. I would have to put some sort of housing around it... which might look crappy.
https://rinkerboats.vanillaforums.com/discussion/comment/92627#Comment_92627
