Annodes needed for 342
buggyjdavbuggyjdav Member Posts: 134 ✭✭
Anyone know the specific annodes/zinc's needed for a 342? I have the 5.7 Merc Horizons with Bravo II drives. I want to get them on order. Thanks!
    Are you sure you have Bravo II and not Bravo III?  I have Bravo III and thought most, if not all 342 had them.
    Bravo III come in 2 flavors, pre and post 2004.  The older one has one anode disk in the caviation plate.  The newer ones have 2 anode disks in the  caviation plate.
    As far as I know there only 1 flavor of Bravo II.  If you go to BoatZincs.com they should have them all listed by outdrive.
  • CarsnmorellcCarsnmorellc Member Posts: 230 ✭✭
    Pretty sure that boat has Bravo 3's
    2001 340 Fiesta Vee 20P Hill Marine and 2 new 6.2 Horizon motors. Whine Down
  • buggyjdavbuggyjdav Member Posts: 134 ✭✭
    I am going off the surveyors report, I suppose he could have made a mistake, I made one once lol. I have the serial numbers of the drives, will research to see if I can cross reference to the drive model somewhere
    Do u have 1 or 2 props on outdrive
    2002 Rinker FV 342
  • LaReaLaRea Member, Moderator Posts: 7,999 mod
    www.boatzincs.com, best prices, great quality.  I've used them for many years.
    X2 on boatzincs.com. I have also used them for many years. I got my new anodes a few weeks ago. There are 4 of us that order together to save on shipping costs.
    I have a single prop per drive
    Yep, so likely Bravo II as your survey reported. If the survey shows a drive serial number (and a decent survey should, but might not) then it's also easy to look it up.
    I'll add my support for boatzincs.com
    Best price I found anywhere and shipping was very fast and reasonable rate.
