2002 232 question
I have the 02 232 cuddy cabin with 350 MAG MPI Bravo 3 with 28p props. MY performance has been fine for the most part but i have a problem at wakeboard speeds keeping the boat on plane. I am torn between going to the hill marine 26p 4x4 or putting a set of trim tabs on the boat, or if i should do both. I boat in kentucky so its never in high altitude. Anyone here running the 4x4's on a 232 or 246 (similar size) and/ or running trim tabs for same reason and have some feedback before i spend the coin on these things.
I see a big discrepancy here on what people are talking about. Coop232 says he has a Bravo3 drive not Bravo1, which it looks like JeffH is showing and talking about. Huge difference. B3's have 2 props, B1 has 1 prop. B3 has different gear ratios than B1 drives.
I put Lenco 12"x12" Lenco trim tabs on my 232 B3 with 350Mag 4 years ago because it lacked low end plane and hole shot like you are stating. I had 26p props on it. Trim tabs made a big difference on low speed plane. I switched to 24p props last year because I wasn't close to 5,000 rpm top end. The 24p props made a big difference on low end power, low end plane, and got me to about 4,900 rpm top end.
I bought new Hill Marine 24p 4x4 props for my 232 for this year. I spoke to Hill Marine and they said the 4 blade props won't change top end rpm but will make a big difference on low end plane and hole shot. I haven't put them on and tried them yet.
Summary: 232Coop what is your top end rpm with 28p props? It can't be in recommended rpm range. Like I said with 24p props my top rpm is 4,900 rpm now. You need to choose your props by the top end rpm.
Since I bought new 24p Hill Marine props to try out, I have a set of 26p and 24p B3 props. The 24p props have 28 hrs on them. The 26p props have 180 hrs on them and they are like new also. I am willing to sell either set of props fairly priced.
To me it sounds like you may be over propped. If I did it all over again I would get my props in specs before spending the money on tabs. Yes the tabs make ride and stabilization better but props should be first IMO.
Rob
