2001 340 FV mattress size
Does anyone know the dimensions of the pads in the aft cabin on a 340 FV? I would like to order a mattress topper to add a little more padding and can't remember if I need a full or queen size? Has anyone that has done this in the past found a perfect fit, or did you have to trim the topper to make it fit?
We used an electric knife to cut the topper we used in our old 280. Had to cut the edges to fit the slant of the V-berth walls as well as make it sorta triangle shaped. Worked like a charm.
