A/C Not Working
2004 FV 342. When I turn on the A/C or heat the fan comes on but when the compressor goes to kick on it trips the breaker. I ordered a new solonoid and hope that resolves it. Anyone else ever have this issue or have any ideas?
1. A bad capacitor. Or less common a bad wire connection (possible corrosion if in salt) somewhere on the pump or compressor. Cheap fix.
2. A faulty water pump. I imagine this is a pretty easy DIY repair.
3. A bad compressor. They aren't worth fixing. You would be looking at a new unit, which are stupid expensive ($3k+).
