Cleaning Stainless Steel prop back to new?
J3ff
Member Posts: 4,062 ✭✭✭✭✭
Anyone know of a way to clean this without scratching it up ? Hoping there's some kind of magical substance to buy that will get rid of the junk on it!
These were new in July of last year..
It looked like this on Sept 26th.. so a couple months?!
BTW: on SS props. NEVER use a steel wire brush/steel wool. They leave behind iron and it will cause corossion.
Again: Big No-No: do not use any steel brush/pads on SS!!!
Because a nicely waxed outdrive with shiny props look great on the back of my lift!! Very easy to keep nice when on the lift.
and they will spit shiny
i never was a squid, but used those rascals for transport from time to time. one of the things i watched them do and then tried myself to great success is 'bug juice' aka kool aide. mix it up THICK, like the consistency of ketchup or so... spread it on... let it almost dry... spray it off, and use a towel to wipe off the stubbornness if any and any film... clean as you can get with acid (pssssst- it is acid, just not the kind that'll burn the crap out of you or mess something else up if you spill/overspray it somewhere/something organic).
edited to add: Bug Juice is either lemon flavored or orange flavored... you want the citric acid. use either of these, preferably lemon... red (cherry) or purple (grape) don't work as well and will stain some surfaces.
