Waxing/Polishing without water
Willhound
Member Posts: 4,236 ✭✭✭✭✭
No running water available where my boat is blocked for the winter. I did have it pressure washed last fall and the hull is relatively clean if slightly tea stained below the water line. I'd like to use a wax or
maybe a polish with PTEF to seal the hull (not painted) and shine up the areas above the water line. I'm OK with the little bit of tea staining below the water line. No water, no problem?
