Gear lube Reservoir
onislandtime
Member Posts: 309 ✭✭✭
Drives were pulled over the winter, painted and new upper seals replace. 2 trips out and have had to fill the gear lube reservoir. I'm told this is normal sometimes after drives are pulled and put back on. Anyone experience the same? Obvious if this happen again I think this maybe a leak. I'm thinking the reservoir is a 1/4 of a quart. So I have now used a half of quart filling the reservoir.
