Reverse Polarity
aero3113
Member Posts: 9,605 ✭✭✭✭✭
This is the first time I’m using shore power hooked up to my house. When I plugged in the red reverse polarity light came on. I turned on the main switch and the green light came on. Everything operates as it should with power on ( range, microwave and battery charger). Is it normal to see the reverse polarity light on when plugged into the house?
Might be a good time to buy one of these if you don't already have one:
https://www.homedepot.com/p/Dawson-3-Wire-GFCI-Outlet-Tester-DET300/206375583
There's an easy way to remember. The black wire is the hot (120 volt), and the white is the neutral (return to ground). When you look at a 3-prong plug or outlet, one blade is wider than the other. Just remember: the length of the slot is like the length of the word.
short = hot
long = neuuu-trallll
