Horn not working
joey91279
Member Posts: 19 ✭✭
I own a 2005 Rinker Captiva 192 and the horn is not working. The previous owner put in a new horn and said it worked a few times and then quit. Does the horn have a fuse somewhere between the horn itself and the rocker switch at the helm?
Any help is greatly appreciated!
Thanks,
Joey
Thanks,
Joey
remove horn and with a volt meter connected to neg/pos posts press horn button
do you get 12v
if so horn is bad.
Mark
2019 MTX20 Extreme
you can always keep the cover and mount 12volt air horn inside
