Care of Cherry Floors
SpyderwebSpyderweb Member Posts: 939 ✭✭✭
I have the Cherry and Holly floor in my new to me 2008 330.  1st time with wood floor.  I'm concerned about care of it.  Do I need to be concerned about every little drop of water being wiped up right away because it will leave a water spot?  We do have people in and out of the water all the time, so it's going to happen
The floor is has the oil finish, not polyurethane.
Best Answer
  • LaReaLaRea Member, Moderator Posts: 7,880 mod
    You should wipe up any liquids, but it's not like you have to immediately swoop in with a towel.  Water can sit for a little while and not leave spots.  Chronic water will cause damage for sure.
    I wipe mine down with Murphy's Oil Soap 3-4 times a year.  Pour it on a rag, rub it in, buff with a dry microfiber towel.  I'm sure there are other methods too.
    I used to use teak oil on my deck floors
    Agree with LR, I wipe up water as soon as I can. Good to clean and re coat here and there to protect
  • Dream_InnDream_Inn Member, Moderator Posts: 7,753 mod
    Yep, I agree with LaRea too.  Coming from the Midwest, I've always been a huge fan of something called Milsek.  It is just fantastic on wood!  Makes my kitchen cabinets look like new!
  • SpyderwebSpyderweb Member Posts: 939 ✭✭✭
    Is Murphy's Oil Soap just a cleaner or a protectant too? For example, after applying it, would you see water droplets bead up more?
    LaRay, Yes I just saw Alswagg's response on another thread about using virgin mineral oil, same as what's used on butcher block.  I think I'll try that too.  Thanks.
