Water Heater Elimination.
micktu
Member Posts: 7 ✭
My electric water heater hasn't worked in years. I disconnected power to it back then until I had time to look into it. This has not been much of a concern because we still get plenty of hot water after running the engine. The old heater started leaking rusty water last year. Has anyone done, or heard of looping the hoses in order to eliminate the water heater, but still get hot water from the engine? Would this work?
Unfortunately no. You still need the tank to heat the water.
See the picture below. The electric heating element is in the center, and the heat exchanger runs along the outside.
I think you are stuck spending $300 for a water heater.
http://stevedmarineconsulting.com/water-heater-primer/
@micktu, just install a new heater. Its nice to have when you need it.
