Boat stereo problem
Spyderweb
                    Member Posts: 947 ✭✭✭
                    Launched my new to me 2008 330 EC and am discovering gremlins.  This one involves the stereo.  It's a Clarion M455A that I believe to be original.  Sitting at the dock with with nothing running except charger, stereo won't turn on, as if there's no power.  Start the engine, push the "on" button and stereo immediately turns on.  Despite the charger being on for about an hour, I suspect bad house battery.
Next day, after having charger on all night I try radio again and nothing. I run jumper cables from new battery just bought a week ago to house battery, and still nothing. Start engine, and stereo start right up.
With jumper cables off, and charger turned off, voltage at house battery is 12.90. Voltage at stereo itself is 12.78. Seems like this should be adequate to run stereo but it doesn't. Start engine, and voltage at stereo is 14.13. Stereo works.
What's up?
What's up?
I'll give this a try next time up.
The remote on only uses a few milliamps, so it won't drain your starter. The stereo's main power comes from the house battery.
Side note: on mine, turning to accessory would sometimes make the tachometer hour meter start running, even with the engine turned off. Check yours to make sure it's not doing that.
The remote-on wire is hooked to the starter battery via the ignition switch, but it draws essentially no power, and can't drain the battery. It's just a small-gauge wire that tells the M455A "whenever you see 12 volts here, turn on the stereo system."
Turns out the head unit was bad.
Replaced it with a new M303 & new remotes & Kicker speakers. Works awesome now.
Don't even attempt to figure out what went bad with your 455. I got a big ol 'bill' from a local stereo shop trying to sleuth out the issue.
