6 pin Transducer
aero3113aero3113 Member Posts: 9,634 ✭✭✭✭✭
Does anyone know why they call it a six pin transducer when only three pins are being used? Airmar B60 6 pin transducer.
Transducer
Plug on GPS harness
    Yup there's 6?? Lol
  • aero3113aero3113 Member Posts: 9,634 ✭✭✭✭✭
    I found this print, just curious why the three pins aren’t used??
    May other pins for temp,speed,then sounder.
    But there empty spots, no pins in them.
    edited May 2018
    I finished the transducer install today! I laughed when I saw how easy it is to acces the starter with a hole in the bottom of the boat!! Hardest part besides getting the courage to drill the hole was tightening the nut in the tight bilge. I was able to put it next to my indash depth transducer because it runs 192 kHz and the new one is 200 kHz. Just have to touch up the bottom paint around it.
    edited May 2018
    Post edited by aero3113 on
    I also noticed that the extension for the transducer where it hooks up on the transducer side only has 5 pins! I tested everything last night so I know it’s the correct transducer. Just strange it’s a 6 pin transducer that uses 3 pins at the GPS and 5 pins down at the transducer!!
    Wow! You've got more balls than me. Just the thought of drilling a big hole in a hull gives me the jitters. Off topic, but seeing the plywood layer, I thought I saw somewhere that Rinker used pure glass for the hull to above the waterline...obviously not.
    Yea, took a lot of convincing myself to drill the hole but went for it! Hopefully @Alswagg will give you an answer about the hull.
