Ac and heat
Happened the last 2 trips to the boat. Thermostat is set to 73 degrees, but cabin is 61 degrees and heat indicator light is on the thermostat...but compressor not running or blower.
Reset it and then it ran flawlessly Friday night and all day Saturday so far.
Thoughts?
Thoughts?
However came to boat to only realize the thermostat was stuck on 74 degrees anf temp was really 80+ degrees in the cabin...and would not respond to any button presses including on / off. I had to switch shore power on / off to get the thermostat working again.
Time for a new thermostat???
