Mercruiser 5.7 Fresh Water Cooled : Raw Water Pump Jammed
 pistole
                    Member Posts: 158 ✭✭
pistole
                    Just to share :
Took the 330 out yesterday with the family. This has a pair of Mercr 5.7 efi's driving Bravo3. Got to a fishing spot , dropped anchor and killed the motors. About an hour later , starboard refuses to start. Cranks but no start. Add throttle , crank and then she starts , but with a very loud shrieking sound from engine compartment. Killed that engine.
Did not want to prolong stress for family , started up port engine and limped home with that one engine. Docking with one engine when you're used to two is quite an experience (note to self).
Arranged for family's lunch at marina's cafe and then opened up the engine hatch
Long story short , the engine could not start because the raw water pump was jammed and preventing the engine from turning over. I took off the serpentine belt and the engine started right up (killed it immediately , needed to just confirm that the problem was not with the motor).
I rotated the raw water pump's pulley by hand (it turns clockwise , by the way) and it stated to loosen/turn after some effort. I could see that it was working because the water visible through the sight-glass on the sea water strainer was churning.
I put the belt back , tensioned it and started the engine. Runs like a champ.
Has anyone experienced something like this before or could share some opinion on this. I am planning to open up that pump and have a look. Would it be likely that the impeller is destroyed ?
Thanks.
Thanks.
Am getting the rebuild kit.
Larea mentioned my wear plate is not replaceable
And the pump cannot come out as it is trapped by the pump pulley, the pump body and the bottom of the hull.
Am almost out of ideas.
Help
Kano Aerokroil Penetrating Oil, 10 oz. aerosol (AEROKROIL) https://www.amazon.com/dp/B000F09CEA/ref=cm_sw_r_cp_apu_i_UJvaBb9X20REF
Will look at the bolt extractor.
Thanks
Andy
Was a hard day yesterday.
