Yes, another winterizing Hotwater tank question from a Newbie....Sorry!
So I drained all water from fresh water tank then opened the drain on hot water tank and pressure relief valve and emptied it (left drain open). I have a bypass valve installed to so I don't fill hot water tank with antifreeze. . I then filled the freshwater tank with about 4 gallons of anti freeze and ran threw all the faucets till pink. My question is there is two hoses that run from the engine to the hotwater tank (here is some picture) both are black one run from what looks like the exhaust and the another looks like the block. Do I need to disconnect these and fill will antifreeze? Is this the water that comes from the exhaust and then circulates threw the hotwater tank to heat the water inside and then returns to the block?
I use a small marina and they mostly do small boats without water tanks. Any help would be much appreciated!
I can only imagine that it's a bummer to wrap it up and break out the snow mobiles but every dog has his day and I often envy those cool clear fresh water lakes you guys get all summer. Kinda wish I'd have had the experience you guys have skiing, hunting and snowmobiling too.
Saltwater isn't a big deal unless you neglect the boat. It's all about rinsing/flushing everything EVERY time you use it but the upside is that my season lasts 8mths too.
And just to stay on topic re a hotwater heater.....I have one on board but NEVER have to turn it on. Gulf temp was 83* until last week. We had a couple mornings recently when the air temp was 82* at SUNRISE. omg somebody turn down the broiler, I'm well done. B-)
