Shift fault
I've been getting an intermittent shift fault. I may go days without it popping up, and then some days it'll do it frequently. A lot of times I can just shut the boat off and start it back up and not see it again.
The actual faul on VVMobile says
1105-6
Shift fault
Neutral switch
I'm sure that someone has seen this? Is it more likely going to be the shift sensor itself, or a cable adjustment? Any other ideas?
350 MAG/Bravo 3
1105-6
Shift fault
Neutral switch
350 MAG/Bravo 3
Kind of like @GMSLITHO, a lot times I see this at high power settings, but not always. It seems pretty reproducible if I go to WOT though.
