Bilge mounting areas
aero3113aero3113 Member Posts: 9,590 ✭✭✭✭✭
Just curious what is in the mounting areas that the batteries, water/waste tank and other accessories are mounted to in the bilge. Is it hollow? Filled with foam? Reason I ask is that my cousin has a 2004 24 foot SR and one of his trim tabs tore off last year. He was thinking about drilling a hole in that area to inspect for water and see if he should drill a drain hole. What do you guys think??
