Outdrives only come up halfway
Spyderweb
Member Posts: 947 ✭✭✭
Had an "incident" today. Due to unfamiliar waters and stupidity I grounded the 2008 330. Port outdrive was hung up on a rock after hitting at idle speed. Fellow boater helped out by pulling boat around in a circle that repositioned boat on stone, then was able to carefully pull boat free. I lifted sterndrive all the way up, props amazingly seemed unscathed. Decided to take it back into marina (1000') to dock and double check everything.
After docking, when I tired to raise outdrives, they both only came up halfway. Like trip position, not trailer. Tried trim switch and trailer switches. All moved drive(s) up and down, but only halfway. Not all the way like it just did on the lake. Any ideas what's happening here and the fix?
i doubt impact took out both limit switches but you never know.
i would definitely pull the boat out and check the bottom and drives for damage
one puck is the sender and the other is your limit switch for trim up
i would trace to see if your are getting a signal from trailer switches
i mean you need to lift the boat out anyway to check the hull and drives for damage
at that time you can check each puck on the drives and wiring leading from them
for now check if you are indeed getting power to the pumps/ solenoids when trailer button or buttons is pushed
What does that tell us?
Is it likely that each trim limit sensor (on the port and starboard drive) went bad at the same time?
