What I found when doing tuneup
The corrosion was pretty bad but look close at the screw hole. Broken on both distributors. You can tell the previous owner or previous owners mechanic tried to fix it with some type of prematex. Is this a part that can be replaced or does the whole distributor have to be purchase.
You can buy a repair kit
I guess the distributor has to be removed to put this repair kit in?
