I just reinstalled riser and torqued to 35lbs in three stages. all has gone well but forgot to attach the 20 amp breaker. Can I remove the bolt and re torque or leave it and tie it off somewhere?
They are the original @F1100. I had a parts guy at a local dealer say I could reuse a few weeks ago. I will check again tomorrow when I go over for a set of exhaust flappers to be sure. Thanks for the heads up.
If you have a manual, they will either have a TTY symbol, or a "x" near pointing to them if they cant be reused.. in most cases anyway..or some mention that the bolt is 1 time use
Thanks @Alswagg@F1100. Riser castings still looked good. It is always flushed after use in the salt and average 30 hours per season. Exhaust shutter was stuck in closed position (50% free). Replacing that this weekend then that's it for the season.
