AC strainer location 330 Express Cruiser
heavyrinkerheavyrinker Member Posts: 2
we had the boat out to install the transponder for our new GPS, after it was put back in the AC is causing an HPF error. One of the suggestions was to clean the AC strainer. I checked the AC unit itself and cannot locate a strainer, neither does it appear to be in the engine compartment. Any suggestions where to look for it?
(also someone said that the AC may need to be primed after it’s been out of the water, any input on that?)
Thank you!
