Surge protector
So I recently installed a 3 bank charger and the corresponding thru-hull fitting. Its a standard 3 prong 15A setup (not 30A like OEM shore power). I have a quality 14/3 medium duty extension cord & Marinco 30A to 15A adapter.
Is it necessary or advised to install some sort of surge protector between the charger & extension cord? I just want to safe guard my new investments.
2013 276 Cuddy ~ 350 MAG / B3
https://www.fisheriessupply.com/marine-shore-power/isolation-transformers
Wire in where the charger plugs in now and if there is a short it will pop before frying the charger
It's a prosport 20 plus, 3 bank 30 amp
Most boats only have two places that can potentially save electrical device in question.
one would be your main 30amp breaker at the pole
two is your boat breaker thats wires into the circuit for whichever item is in question.
short protection or surge protection is usually handled by the decide itself. That’s of course if it has one.
to truly protect your ac product you need to install separate surge protectors for each breaker and battery backups.
you are fine joe and have no worries lol
we are talking about a battery charger here and not a high powered electrical turbine lol
