engine quit on me
luvinlife
Member Posts: 501 ✭✭✭
The admiral and I were happily cruising to one of our favorite coves in our 270 in Rhode Island when the engine quit. Everything was good, engine temp and oil pressure then nothing. It stopped like someone pulled the kill switch. Had to get towed back. I am guessing it’s fuel (5.7 MPI). Has a half tank so I didn’t run out. Changed the fuel water separator, no dice. The marina is going to look at it hopefully tomorrow. Hope it’s nothing too bad!
check spark. primarily, check the breaker. then, check fuse panel. then check the coil wire to the dizzy. check grounds. (sniff for fuel, run the blowers a few minutes) pull the coil wire from the center of your dizzy and lay it across the exhaust manifolds and observe for spark. if there is? pull dizzy cap and see what state the rotor button and points are in.
Andy
For spark pull the coil wire out of the dizzy like @212rowboat said. If no spark make sure the remote (throttle handle) safety thing (lanyard) is not cutting out power.
I think I would also lean to electrical glad you weren't 1/2 way to block!!
If it's tripped, next question: why?
Ti diagnose Id toss a timing light on any spark plug wire and turn it over to check for spark, if timing light doesnt flash there is no spark. If no spark i then check voltage to coil. Then i bench test coil. If all checks out id then replace the ignitor.
there are 3-4 relays and a fuse block with 4 fuses and 5th being a spare usually.
main breaker can be just reset.
fuses sometimes are either behind the engine or port side riser area
@luvinlife : if the fuse was blown, it is worth your while to figure out why. if it was just old and tired, that is one thing. if it's corroded that's one thing. if it is a healthy fuse that blows again, that is a whole other thing and something you're gonna want to investigate. ...... just a heads up.
Does the bravo use an interrupt switch?
