Need a new oil pan
aero3113
Member Posts: 9,743 ✭✭✭✭✭
Went to head out with my wife today and noticed my oil pressure was bouncing. I figured it was my sender and kept an eye on it. About 15 minutes in i started to hear lifter noise and Pulled back to idle and the oil pressure went back up to normal but still had slight lifter noise so I shut down and dropped anchor. I checked the oil and there was only a dot on the tip of the dip stick! I checked under the engine and it looked like it was just water so I put 3 quarts of oil in (all I had). Started up and there was some lifter noise but quickly went away and oil pressure was normal. Was able to get back to the slip with no issues. Once I tied up and shut down I looked under the engine again and could see oil dripping from the bottom of the pan! I reached under and could feel how corroded the area was.
I have a 2001 242 with a Mercruiser 5.7,Is it possible to replace the pan in the boat or does the engine need to be pulled? ( If it doesn't need to be pulled i can do it myself) If it needs to be pulled what do you think a shop would quote me to do the job?
those jobs are a pain.... it takes several hours to get the thing apart to where you can get to it, and about ten minutes to actually do it, and another several hours putting it back together..
I hope you're considering a new oil pump and pick up while you're in there... they aren't expensive, and the mechanic will be right there, anyway..
Thanks for the post. The CO post someone else added might've saved a life and this one might've saved an engine.
Mike
again, make sure and get an aluminum replacement pan...
I recommend header paint.. on as clean a surface as you can get.. :-)
You've certainly got your work cut out for you in cleaning that bilge but the boat looks great. At least it'll be completely serviced with impeller/oil pump/drive oil and re-check the O/D bearings and alignment. All stuff you won't have to worry about for quite a while.
Nothing beats cramming a cell phone on video mode (or picture mode if you can trigger it) and a light way back in tight spots to see what lurks way back/down in there. Thanks again for your post. I'd have never thought to check my oil pan for a potential leak if you hadn't posted, and thanks for the pics. Relentless afternoon rains here so I still haven't gotten back to mine to see if it's repairable. Mike
I'd highly recommend my fellow boaters with a boat over 6y/o to cram a camera under yours....
I got pretty good at shooting pics with my arm folded backwards and my face crammed against the manifold
2019 MTX20 Extreme
The dremel with an extended flex head and wire wheel made it work. Along with my new yoga move.....the manifold face, inverted arm.
Hope it works out just as well or better for you guys too.
Mvn, I actually had missed a small spot in that pic but it was only one pic of dozens I had to shoot to check my work. Awkward but it worked. You guys have a great season, mike
