Blind or something to keep the light out
cls10105cls10105 Member Posts: 389 ✭✭
edited November 2019 in General Boating Discussions
Hello everyone, does anyone know what to use for hatch window to block the light from coming in and waking me up in the mornings. This is for a 2002 342 fv. Thanks for the help
cruising on 6. tw0s
    Have a local canvas shop make u a cover then attach to the buttons on the on the 4 corners of frame. You might have to pry off the button covers
    2002 Rinker FV 342
    It also stops condensation from dripping on u
    2002 Rinker FV 342
    I had a canvas shop make me up a square for my hatch. They also made me up some rectangles for the port lights. My cabin is rather dark now.
  • aero3113aero3113 Member Posts: 9,878 ✭✭✭✭✭
    My 08 330 has a shade/screen that is mounted to the hatch frame. Pull one way it’s a screen, pull the other way it’s a shade. They both separate in the middle by a magnet to have it fully open. All of the hatches have it installed, I thought it was a pretty cool item.
  • cls10105cls10105 Member Posts: 389 ✭✭
    @aero3113 that would be nice i wonder if they make that for mine
    cruising on 6. tw0s
    Made by Oceanair. They make a bunch of different sizes that might just screw on to your existing hatch.
    Bomar also makes them I believe
    The ones made by Bomar are a little expensive. I was going to go that route but the canvas option was much cheaper.
    Mine has a built in shade on it.
  • IanIan Member Posts: 3,064 ✭✭✭✭✭
    Our dock neighbor with a Mariah has canvas covers on the outside that I thought I could get made but was unsure if there was enough room in the Bomar frame for the snap base screw and still seal okay. Anyone done this?
    Well I'm a tight a$$ this what I used.
    Stearns Boat Cushion
    @raybo3 could you check and see if it has a part number we have the same boat so it should work. I would really appreciate it
    cruising on 6. tw0s
    @randy56 lol...i have been using a piece of carpet that i put an owl on to hold it down. But i would like something on the inside if wasn't crazy expensive.
    cruising on 6. tw0s
    @cls10105 my boat is put away and shrink wrapped for the winter. I could certainly check in the spring. I am assuming you mean the one that is right over the V-berth. Are you sure that yours does not have the built in shade and screen? I thought they all had them.
    It was missing when i boat it. It was missing a lot of stuff. I guess i will wait till Spring thank you sir
    cruising on 6. tw0s
    If it was missing, I would think a big part of your hatch frame would be missing. They do stowaway pretty neatly, it’s possible it’s there.
    @aero3113 nothing looks broke but nothing is there except the window and latches to open it. No screen or nothing.  We have looked the boat over pretty good and haven't saw it.
    cruising on 6. tw0s
    What I meant by stowed, the screen and shade get tightly wound in the hatch frame. See the link below.
    https://www.defender.com/product.jsp?id=47732
    @Liberty44140, good morning , hey liberety does your 342 have the built in screen if so do you think it would be same size as mine.
    cruising on 6. tw0s
    Our 342 has the built-in sliding screen/blackouts.  GLC has a few different sizes.
    In our old 280 we had the "pop-in" screens.  Basically a flexible wire frame with screen material attached.  The PO of that boat cut pieces of foam poster board that was black to fit in the windows and stuck them up between the hatch and the screen.  They worked pretty well.
    @Stodge. Thats not a bad idea..thanks man
    cruising on 6. tw0s
    Yeah. I would like to get the size since i dont have a screen. I have to buy something either way i go.
    cruising on 6. tw0s
    Does anyone have a picture they could post of the 342 with the built-in sliding screen. So i could see how it is attached
    cruising on 6. tw0s
    U would have to remove button covers than unscrew frame and change with new frame with built in screen
    2002 Rinker FV 342
    @bella-vita, gotcha, i see the 4 button covers i just dont have a frame or anything attached to it. Thank you sir
    cruising on 6. tw0s
    @cls10105 If you have access to your why not take a picture of yours so we can see the set up you have.
    i think you can zoom in and see the screws
    @raybo3, thanks man..that looks really nice
    cruising on 6. tw0s
    @reneechris14, you added the pic it looks nice thanks man
    cruising on 6. tw0s
    cruising on 6. tw0s
