Bow/Anchor wash down.
aero3113
Member Posts: 10,085 ✭✭✭✭✭
Has anyone installed a fresh water wash down at the bow of the boat? Would be nice to rinse the anchor and bow. Could you tee off of the cabin sink? Or would a separate pump be a better option?
It seems like the the best way to do it would be with a dedicated pump to get the pressure you would want. Would be nice to plumb it into the factory fresh water tank. This guy installed his own tank.
https://youtu.be/3ocWG_uIxvg
1) what type of faucet to install?
https://www.thechandleryonline.com/product_info.php?products_id=341#description looks like a good option
2) hot or cold water? Tempted to use hot because why not?! I suppose it will rarely be hot after being anchored for hours/overnight
3) where in anchor locker to mount spigot
I think I will try the existing line first and if the pressure isn’t sufficient I will upgrade the pump. The Jabsco city water connector regulates to 45psi I believe so the fixtures must all handle that at a minimum.
Love that stuff.
