Air Conditioner Newbie, Some Questions.
aero3113
Member Posts: 9,660 ✭✭✭✭✭
I was playing around with my AC today. When I first turned it on I set it to 65 and the cabin was at 66. Only the fan was blowing, the compressor wasn’t on and no indicator light next to the snowflake. I kept it like this for a while thinking it would kick on, still just the fan. I think it was in auto mode, is this why the ac didn’t come on? After a while I turned the system off and back on, the compressor came on. I think at that time the cabin was at 67. I had cold air with the indicator light on next to the snowflake. What did I do wrong the first time? Also, what is the purpose of the main/air conditioner switch? There’s also 2 other ac breakers (there’s one on the right that isn’t in the second pic). This was all on shore power.
Re not kicking in at first a temperature difference of only a degree may not be enough to switch to cooling so when it said 67 that was enough to kick in compressor.
If you have a Vector Compact I have attached the manual, there are some programming options also you may want to adjust.
Maybe that's why mine wasn't pumping water initially last year. I assumed since I just put it in there was air in the line and it was just taking some time to prime. These systems definitely need to have the manual on board because they are not exactly user friendly, lots of odd button pushing.
