battery selection
rasbury
Member Posts: 9,010 ✭✭✭✭✭
Think it is time to replace at least my starting battery....the ones I bought at the auto parts store I have had I think for 3 years and I think this is why my windlass is having problems...just to long a run on an old battery....I hate to ask this question and I don't have 2 grand to drop in batteries but can you break it down a little as to what group I need and CCA and then I can go shopping.....
https://www.samsclub.com/p/duracell-agm-deep-cycle-marine-and-rv-battery-group-size-sl34magm/prod3590225?xid=plp_product_1_7
I’m hoping the extra weight will also help with my list to starboard.
If i were buying for resale and passing these onto a customer i have a 40% mark up margin. Thats still under 250 a battery.
I buy direct from a battery supplier, im sure they are paying less than 75 to 80 for these batteries.
Come up to the Greenville area and I'll make you a deal lol.
That said.....
I bought a really nice 80a charger recently, and was able to recondition and restore 8 batteries i had sitting around. Flooded lead acid, mind you... all group 27... the charger cost $225.... replacing those batteries would have been over a grand... they seem to be holding up just fine, too. A couple are over 10 years old.
If you do go to the newer style AGM, GEL etc - just watch your onboard charger settings. (beating a dead horse here)
If taken care of the newer style should last longer than old LA's. Key word is 'should'.
2 cents
But here's something to consider. Don't worry about the windlass because as far as I'm concerned it shouldn't be used without the engine running and the alternator feeding the battery. My rationale is that while setting the anchor I want the engine running so that once I drop anchor and let some rode out, I can give a slight bump in reverse to set the anchor. Or, if I don't like the anchor set, I can pull up and reset it without having to go through the whole run blower/start engine thing. And when pulling anchor to leave, I never..never...pull an anchor without the engine already started and running. What happens if you pull anchor and then it doesn't start? Hastily try and drop the anchor again? What if you lose power and can't drop the anchor...now you're pooched.
