Kohler 5E mess
Pat310
Member Posts: 603 ✭✭✭
When I purchase my 2003 310 last August the Generator was not running at survey and I was foolish enough to take a $500 credit because it would take a few weeks to get a Kohler tech to look at it according to broker (How bad can it be he said, it only has 15hrs on it). If only I was a member here before purchase I would have known how bad. My impatience got the better of me as season was winding down. Fast forward to this year and I’ve replace the impeller, the coupler, the fuel pump and the carburetor. It will now start and run and pump water but only for as long as I hold the starter button. Seems like a low oil pressure sensor to me. Any way of bypassing the sensors to test?
Are you getting any of the K LED fail light illuminated?
The pressure switch looks to be less than $30 though.
Try this test for each of the three fuses: Start the engine, but before you release the starter button, push in firmly on the fuse holder cap, then release the starter button.
It probably won't work, but at least you can rule out this failure. Here are some of my fuse holders -- normal, one side failed, both sides failed.
Here's the thread.
https://rinkerboats.vanillacommunities.com/discussion/7899/generator-acting-flakey-diy-instructions-to-replace-the-fuse-holders
