2008 330EC fuel sending unit
Wondered if anyone has replaced the fuel sending unit in a 2008 330EC and might know part number.  TIA
    edited October 2020
    Thanks!  Did a search and missed that.
    I just remembered that post so I knew what to look for. The search function definitely needs improvement.
    I wonder where the sending unit is on the tank.  I saw the fill, vent and ground wire at the end closest to the motors.  I will need to tear out some foam insulation on that end or remove an interior panel.
  • aero3113aero3113 Member Posts: 9,979 ✭✭✭✭✭
    edited October 2020
    They are right on top of the tanks, easy to access. I think you will have to remove the cockpit refrigerator and an access panel to remove the port side. Starboard side has a small deck plate you can remove to pull it out. I will be replacing my port side sender this winter or sooner.
    Thx
    I am needing to replace the port side.  I know that about 16” of the tank is accessible from the motor compartment.  That is where I see the fill, vent and ground.  The remainder is accessible behind interior panel.   There is a lot of black foam insulation and didn’t want to tear it up if it’s not there.  I wish it was the starboard one.  A lot easier to fix.
    Both of my senders are accessible from the engine compartment on my 2008 330.
    Looked back at that entire thread you sent me.  One of your pics of sender seems to show it close to fill if I am looking at it correctly.
    Yes, both sides are by the fill, vent and ground.
    Thanks again!
    @redlightning , look at my thread again. I replaced the port sender and took pictures.
    https://rinkerboats.vanillacommunities.com/discussion/11152/fuel-sender#latest
